275
RowTemplate - Issue with multiple conditionals within a nested block
I am currently playing around with your rowtemplate feature to achieve a pseudo table look for each specific row in the igrid. A nested block seems the way to go to achieve this and so far its worked wonderfully. However, I came across a instance where I need multiple conditionals within the nested block and it appears to be bugging out on the second if-conditional; if I remove the second conditional the table generates.
I noticed in your 'conditional row template', and pretty much every conditional example, there is only 1 conditional per <td>. Is this a limitation of the rowtemplate?
If this is indeed a limitation, the only reason I need multiple conditionals is to properly set the checkmark for checkboxes used for boolean data I would like to display using the same look as the infragistics checkboxes in standard igrids. Is there some built-in rowtemplate method that can render the checkbox in a row template for boolean property?
Below are the template and the Html wrapper used to generate the grid.
Template:
<tr>
    <td style='width: 100%;'>
        <div style='width: 100%;'>
            <span class='rosite-rowtemplate-label' style='width: 125px;'>Name:</span>
            <span class='rosite-rowtemplate-value' style='width: 200px;'>${NestedProperty.FirstName}&nbsp;${NestedProperty.LastName}</span>
            <span class='rosite-rowtemplate-label' style='width: 125px;'>Gender:</span>
            <span class='rosite-rowtemplate-value' style='width: 100px;'>${NestedProperty.Gender}</span>
            <br>
            <span class='rosite-rowtemplate-label' style='width: 125px;'>Email:</span>
            <span class='rosite-rowtemplate-value' style='width: 200px;'>${NestedProperty.Email}</span>
            <span class='rosite-rowtemplate-label' style='width: 125px;'>Boolean1:</span>
                <span class='ui-state-default ui-corner-all ui-igcheckbox-small' style='display:inline-block'>
                    <span style='display:block' class='ui-icon {{if parseInt(${NestedProperty.IsBoolean1Int}) == 1 }} ui-icon-check {{/if}} ui-igcheckbox-small-on'></span>
                </span>
            </span>
            <br>
            <span class='rosite-rowtemplate-label' style='width: 125px;'>Title:</span>
            <span class='rosite-rowtemplate-value' style='width: 200px;'>${NestedProperty.Title}</span>
            <span class='rosite-rowtemplate-label' style='width: 125px;'>Boolean2:</span>
                    <span style='display:block' class='ui-icon {{if parseInt(${NestedProperty.IsBoolean2Int}) == 1 }} ui-icon-check {{/if}} ui-igcheckbox-small-on'></span>
                </span>
            </span>
            <br>
        </div>
    </td>
</tr>
Html wrapper:
    Html.Infragistics()
        .Grid(Model)
        .ID("igMembersPrimary")
        .Height("100%")
        .Width("100%")
        .PrimaryKey("MemberGUID")
        .RenderCheckboxes(true)
        .Columns(
            column =>
                column.For(x => x.MemberShortID).DataType("string");
        .ShowHeader(false)
        .RowTemplate(rowtemplate)
        .DataSourceUrl(
            Url.Action(
                "GetMembersByType",
                new RouteValueDictionary()
                    { "id", id },
                    {"type", MemberType}
        .Render()
