It looks like this feature is not supported at all. Do you confirm this?
Here is the test to reproduce the bug: http://codepen.io/anon/pen/yjhgz
Clicking on the button should enable the text editor.
Hi Francesc Baeta,
The enable/disable binding is native for knockout and it's supported. But not inside the editor. It should be inside the same data-bind attribute, but outside the extension declaration. In example:
data-bind="igTextEditor: { value: customerName}, disable: isDisabled ", where both customerName and isDisabled are observables.
Here si jsFiddle example with a couple of editors with disable binding:
http://jsfiddle.net/todorpaskalev/L3afN/5/
It looks like this feature is not yet implemented. Here's an implementation example to make igTextEditor support binding on the "disabled" option.
(function() { var igTextEditor = ko.bindingHandlers.igTextEditor; ko.bindingHandlers.igTextEditor = { init : function(element, valueAccessor, allBindingsAccessor, viewModel, bindingContext) { igTextEditor.init(element, valueAccessor, allBindingsAccessor, viewModel, bindingContext); }, update : function(element, valueAccessor, allBindingsAccessor, viewModel, bindingContext) { var disabled, current, editor = $(element); igTextEditor.update(element, valueAccessor, allBindingsAccessor, viewModel, bindingContext); disabled = ko.utils.unwrapObservable(valueAccessor().disabled); current = editor.igTextEditor("option", "disabled"); if (current !== disabled) { editor.igTextEditor("option", "disabled", disabled); } } }; })();
BTW, is the binding of all igEditor options planned in future releases?
