Cell is not updated when changing the property value of the model after a column sort in a igHierarchicalGrid (igGrid is OK)
Here is the example: http://codepen.io/anon/pen/wfLln
Hello Maya,
Thanks for the reply.
We are currently developping an application over infragistics + knockout. We need a correction for this issue as soon as possible.
Could you give me the date when this issue will be fixed ?
We planned to buy a license if all the issues we find are fixed. The fact of owning a license will change the priotrity of correction ?
Francesc Baeta
INNES
Hello Francesc ,
We’ve opened a private case for you with number CAS-123296-C5B4R3.
This issue has been logged with a Development ID of 151887 and has been linked to the case. I will leave that case open and update you with any new information after the review.
You can view the status of the development issue connected to that case by selecting the "Development Issues" tab when viewing this case on the web site.
If you have any questions you can let me know.
Best Regards,
Maya Kirova
Developer Support Engineer II
Infragistics, Inc.
http://es.infragistics.com/support
Hello Francesc,
I can confirm this is a bug which I'll log internally. I've also created a support case for this which you can use to get notified when the fix is available.
Thank you for using Infragistics forums!
Best regards,
Stamen Stoychev
