130
Row selection when using igGrid Knockout binding
Does the Knockout binding for igGrid support a callback for changes in row selection?  I couldn't find it described in the help documentation.
  • 130
    Verified Answer
    posted in reply to Dirk Watkins
    Dirq, thanks for you reply.  I actually found a better solution for basic row selection using the row selection event provided by the igGridSelection module.  I hadn't known to look there before.   To wire it it I do something like the following where onRowSelection is a public method on my viewmodel:
    <table id="grid1" data-bind="igGrid: {
    [other options...],
    features: [
    mode: 'row',
    multipleSelection: false,
    rowSelectionChanged: onRowSelection
    {name: 'Updating', enableAddRow: false, enableDeleteRow: false, editMode: 'none' }
    }"></table>
  • 1015
    Suggested Answer
    I'm doing it, but it's messy right now until IG puts out a better way. (igGrid, IgniteUI 13.1.20131.2143)
    I put my igGrid initialization in a function like this:
    function loadControls(viewModel){/*init the grid in here so i have access to the view model*/}
    I then use the RowSelectors feature and handle the checkBoxStateChanged event like so:
    checkBoxStateChanged: function (evt, ui)
    	//Knockout ViewModel, but it could just be an array
    	var boundModel = viewModel.selectedItems;
    	//the record in the grid
    	var r;
    	if (ui.isHeader)
    		//clear my viewModel for later re-adds
    		boundModel.removeAll();
    		if (ui.grid.selectedRows().length > 0)
    			if (ui.state == 'on')
    				for (var i = 0; i < ui.grid.selectedRows().length; i++)
    					r = ui.grid.findRecordByKey(ui.grid.selectedRows()[i].id);
    					if (r != null)
    						boundModel.push(r);
    			return;
    	//my users could change the multiselect option on the fly
    	if (viewModel.allowMultipleSelections() === false)
    	r = ui.grid.findRecordByKey(ui.rowKey);
    	if (r != null)
    			boundModel.push(r);
    		else
    			boundModel.remove(r);
    To complete the "bindings" I also handle the rowsRendered event so it can select on paging, etc:
    rowsRendered: function (evt, ui)
    	var gridId = ui.owner.id();
    	//For each of my saved selected items
    	//select the checkbox on the grid
    	for (var i = 0; i < boundModel().length; i++)
    		//the item's primary key
    		var key = boundModel()[i].Id;
    		for (var x = 0; x < ui.owner.rows().length; x++)
    			//the row contains the key on an attribute data-id="primarykey"
    			var rowKey = ui.owner.rows()[x].getAttribute("data-id");
    			if (key == rowKey)
    				$('#' + gridId).igGridSelection('selectRow', x);
    I know it's not clean, but it gets the job done.
  • 1015
    I'm also looking for a way to bind the selected rows with a knockout observable array.
