60
Event binding stop working after dialog close
I have an igGrid on a bootstrap dialog for editting.  With MVC, the javascript is not on the partial view (dialog) but the parent view.  The parent view's script tag is where I put my $.ig.loader to bind the grid's iggridupdatingeditrowending event with an ajax call to a controller to do server side validation when the done button is clicked during an editting of a grid row.  This works great the first time I open the dialog. However, after I close the dialog by clicking the X icon, bootstrap simply hides the div tag of the dialog.  The next time I open the dialog, the grid loads and renders with all the data and functionality you would expect, except for the iggridupdatingeditrowending event no longer gets fired.
I am guessing that this is because the grid renders without the $.ig.loader function being called, thus it is no longer bound to the iggridupdatingeditrowending event.  Does anyone know of a way to rebind the events?  Here is a sample of the javascript code which I used from a sample project posted in the forum:
$.ig.loader(function () {
(function ($grid) {
//This is a closure which holds the server side validation logic
var _errors = [];
var _rowID, _valid;
$grid.bind("iggridupdatingeditrowending", function (evt, ui) {
_rowID = ui.rowID;
// cancel button is clicked
if (ui.update === false) {
var validator = getRowValidator(_rowID);
_errors.length = 0;
$(validator).igValidator("hide");
return;
ui.keepEditing = true;
$.ajax({
type: "POST",
url: "@Url.Action("ValidateEntitlement")",
data: JSON.stringify({ oldValues: ui.oldValues, newValues: ui.values }),
contentType: "application/json"
}).success(function (data) {
_errors = data;
$(validator).igValidator("validate");
if (_valid === true) {
$grid.igGridUpdating("endEdit", true);
function getRowValidator(rowId) {
var $row = $grid.find("tr[data-id='" + rowId + "']");
return $row.igValidator({
width: 200,
alignment: "right",
checkValue: function (evt, ui) {
if (_errors !== undefined) {
if (_errors.length == 0) {
_valid = true;
return true;
ui.message = "<ul>";
for (var i = 0; i < _errors.length; i++)
ui.message += "<li>" + _errors[i].ErrorMessage + "</li>";
ui.message += "</ul>";
_valid = false;
return false;
_valid = true;
return true;
})($("#igOwners"));
