3790
get the grid table in one array
I need to get all the data in to an array that is shown on the screen. The data provider is no good because its out of order and/or changed. I need basically a snapshot of my data rows and columns included either in the same shot or other calls.
1234
1234
1234
so something like:
getHeaderRow should give me [1,2,3,4]
getHeaderColumn should give me [1,1,1]
getData should give me [2,3,4],[2,3,4]
or just one big array [1,2,3,4],[1,2,3,4],[1,2,3,4]
any thoughts?
  • 15320
    Verified Answer
    Hello seang,
    It's been a while since your last request, but if you still need assistance I'll be glad to help you.
    Regarding your question about getting the grid data and displaying it in an array on the page, I would suggest you to use rowsRendered event and get reference to the grid datasource by
    ui.owner.dataSource.data(), then iterate through this data, which is represented as array of objects, access the respective grid data fields by their data keys and save them to an array. As result this array might be displayed in a simple div element on the page. Here is a code snippet for your reference:
    rowsRendered: function(evt, ui) {
                var grid = ui.owner;
                var data = grid.dataSource.data();
                var output = document.getElementById("dataOutput");
                var dataArray = new Array();
                for (var i = 0; i < data.length; i++) {
                    dataArray.push("[" + data[i].ProductID, data[i].Name, data[i].ProductNumber + "]<br/>");
                output.innerHTML += dataArray.toString();
     Please let me know if I didn't understand your question properly.
    Attached is also a sample with similar scenario for your reference.
    If you have any further questions, feel free to contact me.
    Sincerely,
    Tsanna
    DisplayGridDataIntoArray.zip
  • 3790
    found one wa rowHeader = new Array();
            colHeader = new Array();
            data = new Array();
            data[0] = "";//reserve
            data[1] = "";
            for ( var rows = 0; rows < this.gridIDMap.allRows().length; rows++ )
                datarow = new Array();
                for ( var c = 0; c < this.gridIDMap.option( "columns" ).length ; c++ )
                    colHeader.push ( this.gridIDMap.option( "columns" )[c].headerText );
                    if ( c == 0 ) rowHeader.push( this.gridIDMap.cellAt( c, rows ).innerHTML );
                    else datarow.push( this.gridIDMap.cellAt( c, rows ).innerHTML );
                data.push( datarow );//add row
            while ( $( this.gridIDMap.headersTable ).find( "tr:eq(0) > th:eq(" + x + ") " )[0] )//loop all cells in the header
                data = $( ui.table ).find( "tr:eq(0) > th:eq(" + x + ") " );//get the html element of the cell from jquery
               alert( data[0].innerHTML)
            data[0] = rowHeader;//put this in first
            data[1] = colHeader;//put this in second
    //data[2 ....] contain the data.
    looking for better but this may work. Still no column header ideas yet.
