30
igGrid loses sort after dataBind
I'm evaluating the product and am also having issues with maintaining sorting state.  Our grid data is repopulated via ajax calls and then the data is bound like such
$("#grid").igGrid("dataSourceObject", grid.data).igGrid("dataBind");
When the data bind completes then the sort state is reverted to the default state set when I initialized the grid using the following feature setting.
     type: "local",
     columnSettings: [
         {columnKey: 'NAME', currentSortDirection:'asc'}
     columnSorted: function (evt, ui) {
         grid.sorting.column = ui.columnKey;
         grid.sorting.direction = ui.direction;
I tried to track the changes by getting the values from the columnSorted event as you can see above, but then I can not find the correct location in which to apply them again.  I tried the dataRenderedevent, but this resulted in an infintite loop.
Is there a way to maintain the sort after binding data?
