I am using Jquery 2013 vol1 with ASP.NET MVC4 and Visual Studio 2012 Update 2.
My grid shows the data for the first page, but when I click to go to the 2nd page, no data appears.
I have checked in the breakpoint, and the action is being called to return the data, yet nothing gets returned.
I have also tried decorating the action called by .DataSourceUrl(Url.Action("Index")) with the [GridDataSourceAction] attribute, yet when I do that, I get the following Javascript error thrown by Internet Explorer...
Unhandled exception at line 35, column 25843 in http://localhost:58362/Infragistics/js/modules/infragistics.datasource.js0x800a138f - JavaScript runtime error: Unable to get property 'length' of undefined or null reference
I am not sure how to get this working, no matter what I try it doesn't work.
Here is the code for my Index.cshtml
@using Infragistics.Web.Mvc@using WorkawayWeb.Repository@model List<WorkawayWeb.EditableVisaType>@{ Layout = null;}<!DOCTYPE html><html><head> <meta name="viewport" content="width=device-width" /> <title>Index</title> <script src="@Url.Content("~/Scripts/modernizr-2.5.3.js")"></script> <script src="@Url.Content("~/Scripts/jquery-1.7.1.js")"></script> <script src="@Url.Content("~/Scripts/jquery-ui-1.8.20.js")"></script> <script src="@Url.Content("~/Infragistics/js/infragistics.loader.js")"></script> <script type="text/javascript"> $("#grid1").live("iggridupdatingrowadded", function () { $("#grid1").igGrid("saveChanges"); }); $("#grid1").live("iggridupdatingeditrowended", function (event, ui) { if(ui.rowAdding == false) $("#grid1").igGrid("saveChanges"); }); $("#grid1").live("iggridupdatingrowdeleted", function () { $("#grid1").igGrid("saveChanges"); }); </script></head> <body> @(Html.Infragistics().Loader() .ScriptPath(Url.Content("~/Infragistics/js/")) .CssPath(Url.Content("~/Infragistics/css/")) .Render() ) <div> @(Html.Infragistics().Grid(Model.AsQueryable()).ID("grid1").PrimaryKey("id") .Columns(column => { column.For(x => x.id).HeaderText("Product ID").Width("100px").Hidden(true); column.For(x => x.name).HeaderText("Product Name").Width("250px"); }) .AutoCommit(true) .AutoGenerateColumns(false) .Features(features => { features.Paging().PageSize(10).Type(OpType.Remote); features.Sorting().CaseSensitive(true); features.Selection().Mode(SelectionMode.Cell).MultipleSelection(true); features.Updating().EditMode(GridEditMode.Row).EnableAddRow(true).StartEditTriggers(GridStartEditTriggers.DblClick);
}) .Width("800px") .Height("600px") .DataSourceUrl(Url.Action("GetData")) .UpdateUrl(Url.Action("EditingSaveChanges")) .DataBind() .Render()) </div> </body></html>
Here is the code for my controller
using System;using System.Collections.Generic;using System.Web.Mvc;using Infragistics.Web.Mvc;using WorkawayWeb;using WorkawayWeb.Repository;
namespace InfragisticsMvcApp1.Controllers{ public class VisaTypeController : Controller { public ActionResult Index() { var ds = VisaTypeRepository.GetAllRecords(); return View(ds); }
[GridDataSourceAction] public ActionResult GetData() { var ds = VisaTypeRepository.GetAllRecords(); return View("Index", ds); }
[GridDataSourceAction] [ActionName("EditingGetData")] public ActionResult EditingGetData() { var ds = VisaTypeRepository.GetAllRecords(); return View("Index", ds); } }}
Thank you Martin, setting GetAllRecords()AsQueryable(); solved the problem!
That in fact solved two problems I had, the problem with Paging and the problem with Filtering!
Hi Greg,
The code you posted looks fine. Make sure that the Infragistics.Web.Mvc.dll which you reference in your project is compiled against MVC 4. Its version should start with 4. Here is an example: 4.13.1.2039.
EDIT: Another possible problem is that you didn't pass IQueryable in the GetData controller method. You should check the response of the AJAX call when you request the next page with your browser developer tools. See if there is the "yellow screen of dead" showing some server-side error. Probably the server is complaining that the argument passed to the View is not IQueryable.
Try to use the following code for your GetData controller method:
[GridDataSourceAction]public ActionResult GetData(){var ds = VisaTypeRepository.GetAllRecords().AsQueryable();return View("Index", ds);}
Hope this helps,Martin PavlovInfragistics, Inc.
