40
Igmap requires internet connectivity from client machine for using the map provider data?
I want to use Igmap Control in our website in HTML page.
I want to use OpenStreet provider for igmap control.
Please confirm whether I need internet connection at client loctaion to fetch data from the provider to show the data.
If I use other supported provider then will we need internet connection?
Piyush Agarwal
08149016693
  • 15979
    Suggested Answer
    Hello Piyush,
    Currently an active Internet connection is required in order to download the map tiles.
    One option to overcome this is to not use map tiles if you do not need them. Other possibility is to setup a local Proxy Server which can cache the files needed so they can be used when main Internet connection is down.
    Notice that usage of locally stored map data may require a very big local storage medium – sometimes even in Terabyte range. This is also important aspect that should be considered.
    I have also logged this as a Product Idea with ID - PI13060021. Our product team chooses new product ideas for development based on popular feedback from our customer base.
    If you would like to follow up on your Product Idea at a later point, you may contact Developer Support management via email.
    Please include the reference number of your Product Idea in the subject and body of your email message.
    Thank you.
