1015
Modify value of Read Only Editor in Grid?
Can someone please verify this as well?
I have a few columns in my grid that I need to update via code when another column is updated.  I can't let the user update this field because it is calculated.
I can't seem to update the value via code when I set the column to readOnly: true.
I had to leave it as readOnly: false and capture the keydown event to see if it was tab, or shift otherwise cancel the keystroke.
columnKey: "EstExtPrice",
required: true,
readOnly: false,
editorType: 'numeric',
defaultValue: 0,
editorOptions: {
maxDecimals: 2,
nullValue: 0,
maxValue: 99999999.99,
validatorOptions: getValidationOptions,
keydown: function (evt, ui) {
var key = ui.key;
if (key == 9 || key == 16) {
return true;
else {
return false;
I can update the values of the Numeric editors via code if set to readOnly and if they are on a form outside of the grid.
Is this expected behavior?
