When I have a user that filled in a cell, say with a employee number and clicks tab, then I need my SSN and Name fields to populate. I have gotten the value using the blur event. I can use that to AJAX out the data I need and fill the other 2 columns. I just can't figure out how to call and populate these other columns. I can't seem to get a reference to them and assign a value.
Hello Donnie,
What mhead1 suggested is correct.
I just wanted to add that if you're using editMode: "row" you can also use igEditor.setFocus method.
Best regards,Martin PavlovInfragistics, Inc.
Try the startEdit method call. Get the indexOfRow from your ui.
$("#grid").igGridUpdating("startEdit", indexOfRow, indexOfColumn);
I figured out one issue.
var name = $("#TSDefaultGrid").igGridUpdating("editorForKey", "Name"); $(name).igEditor("value", 'This is a name');
THe only other one I have with this is how to move to the next field they need to input a value to. So after they leave empid then I need to go to occode since I have autofilled name and ssn.
