Hi all,
I am running 12.2 of ignite UI. I was using the combined infragistics.js file and started playing with the grid. However, as soon as I turned on column moving, the grid die not initialize. If I reference column moving JS file directly, then it works. Could someone confirm this is a problem? And an anticipated fix?
I have attached a file demonstrating this.
regards,
D.
This is presumably because column moving is CTP in 12.2.
