I am trying to turn the header on and off in a grid, depending on if it has records or not.
It appears if I set showHeader to false when I create the grid I can never set that to true and have it display.
However if I set it to true when creating the grid and then call _setOption('showHeader', false); It will hide but since this is a private method I was wondering the correct way to accomplish this.
Actually we took the approach of remove infragistics from all of our web products for numerous reasons.
I have heard back from development on this development issue. Based on update from development, I understand this behavior is by design. If on initialization showHeader is false, it'll never be rendered and therefore you cannot show it anymore. I would recommend you to take the approach I mentioned on Mon, Mar 11 2013 12:40 PM.
I hope this helps.
Setting it to false to soon creates issues with rendering, especially if you show or hide columns, I hooked into the iggridheaderrendered event and setting it to false after that seems to work fine, anything before is asking for trouble.
Thank you for the details provided. You can use below line to set header visibility to false using public API:
$("#grid1").igGrid("option", "showHeader", false);
Refer to the “OPTIONS” tab and look for showHeader on the link below:
http://help.infragistics.com/jQuery/2012.2/ui.iggrid
If showHeader is false while initializing grid than the Header table is not created at all. I have also logged this behavior with development 135743. I will update this forum thread once this issue is resolved or if I have heard anything from development.
Meanwhile, I would recommend you to set showHeader to false in the igloader function and show header when you need it as shown below:
$("#grid1").igGrid({
autoGenerateColumns:true, primaryKey:"ProductID",
columns: [ { headerText: "Product ID",key: "ProductID",dataType: "number"},
{ headerText: "Name",key: "Name", dataType: "string"},
{ headerText: "ID",key: "ID", dataType: "number" },
{ headerText: "ProductDate", key: "ProductDate", dataType: "date" }, ],
dataSource:products,
$("#button1").click(function()
$("#grid1").igGrid("option", "showHeader", true);
