I would like to show more series with many different values in time. I use categoryDateTimeX for xAxis as you can show here:
axes: [{ name: "baseX", type: "categoryDateTimeX", dataSource: dateAxisArray, label: "MeasureTime", formatLabel: function (item) { return item.toLocaleTimeString(); }, dateTimeMemberPath: "MeasureTime" }, { name: "yAxis", type: "numericY" }]
dateAxisArray is now just an array with two elements, the first and the last one. I want my series to be appeared on the chart synchronised in time to this baseX xaxis. How can I do this? Right now the problem is that it doesn't show up any of the series is I generate an independent array to be the xAxis.
A couple of hours ago I tried to add an xAxis for each series. This went well, everything appeared but not at its place. Values of the series was far from being synchronised.
Hi Peter,
Please feel free to contact me if you have any questions regarding this matter.
Hello Peter,
I am attaching a sample illustrating how multiple date time series may be synchronized in an igDataChart.
In this scenario a separate xAxis is required for each serie, and each axis should have its datasource set to the datasource of the respective serie.
Afterwards the max and min date time values across all datasource used by the series would need to be calculated, and the minimumValue and maximumValue of each xAxis would need to be set to these values. The labels for all axis but one may then be collapse, creating the appearance of a single xAxis(in the sample the min and max values are statically).
Please let me know if this helps.
