In service release .2086 I could call updateGrid and everything worked fine.
In service release .2113 when I call updateGrid I now get an error. The column it is complaining about has data as can be seen in the record dump below the error
Actually this seems to occur in the .2113 release when PatientListUserObjectsID is set to (none)
I am working on tracking it down, but I cannot understand why the PatientLastName creates an issue
Hi ddally,
I am also facing the same issue.
Did you find the cause for this.
I will really appreciate your help.
Swati.
It turned out I was working with the wrong grid, this happened when I was asking it to update a row with a specific ID, and that row did not exist in the grid
