Hello Infragistic Gurus,
I would like to inquire if I can use the igDialog like the RowEditTemplate for CRUD operations like Add and Edit. Please correct me if I am wrong, if i say that the igDialog can easy be customized in terms of layout design compared to the RowEditTemplate. What I would like to do is, from the igGrid, when a row is double clicked, a igDialog window will open containing the details related to the row clicked in the igGrid which I can then edit. Or i can use the igDialog for adding new records in my Database.
Hope someone can direct me on how to go about what i want to do or a running sample would very much be appreciated.
Thanks in advance for the help :)
Hello Almond,
I have already provided some suggestions to you in the following forum thread:
http://es.infragistics.com/community/forums/t/77922.aspx
If you need any additional information on this matter please feel free to ask there.
Dear Elena,
Good morning.
Thanks for the reply.
In addition to my inquiry, would you possibly know if i can implement something like what is show below:
Some of my table has a lot of columns that i need to layout in a different way unlike the layout being used in the RowEditTemplate.
Thansk in advance for the help.
regards,
almond
Currently we internally use the igDialog in order to implement the RowEditTemplate functionality. For additional information how you could customize this dialog you could check the following links:
http://help.infragistics.com/Help/NetAdvantage/jQuery/2012.2/CLR4.0/html/igGrid_Updating_RowEditTemplate.html
Please let me know if you need any additional information on this matter.
