465
Multiples {{if}} blocks in the same template
I use a template column to customize the display. However, I need to define multiple conditional blocks.
This works:
template: '{{if ${CanEdit} == true}}OK{{else}}KO{{/if}}'
But this does not work (exception in templating):
template: '{{if ${CanEdit} == true}}OK{{else}}KO{{/if}}   -  {{if ${CanDelete} == true}}OK{{else}}KO{{/if}} '
How can I do? I have set up 5 conditions.
Thanks in advance,
Olivier Hélin
