585
Cancel deleteRow
My igGrid is initialized as autoCommit = false. Doing deleteRow() will cross out the entire row. Is there a way that I can cancel my delete action at this point prior to save changes? As the Done and Cancel buttons are unavailable for a row that is being deleted.
Thanks!
  • 23953
    Verified Answer
    Hi Erica,
    You can do this manually.
    First you need to remote the ui-iggrid-deletedrecord css class from the grid row.
    Next you need to rollback the delete transaction from the grid data source.
    Here is an example function:
    Code Snippet
    1. function rollbackDelete(rowId) {
    2.     $("#grid1>tbody>tr[data-id=" + rowId + "]").removeClass("ui-iggrid-deletedrecord");
    3.     $("#grid1").data("igGrid").dataSource.rollback(rowId);
    4. }
    Hope this helps,
    Martin Pavlov
    Infragistics, Inc.
