Is column freeze panes supported in igGrid?
Hello Kathleen,
The Ignite UI 13.2 Volume Release is out so you can check the igGrid Column Fixing feature which is RTM in this release.
For more info please check out igGrid Column Fixing sample and developers guide.
Best regards, Martin Pavlov Infragistics, Inc.
Perfect! Thanks, Martin.
Hello Kathleen Kane,
The Column Fixing feature is currently CTP, so you can try it right away. In upcoming 13.2 release it will be RTM. The 13.2 release will be out sometime in November.
Hope this helps,Martin PavlovInfragistics, Inc.
As of 10/23/2013, has this feature been implemented yet?
Hi Balaji,
We do not support column fixing (freezing) in the jQuery grid at the moment, but this is in our backlog for the next release. let me know if you have any other questions.
Angel
