55
Iggrid's edit row doesn't support textarea
I have a edtable grid, a column's edit type is "Text", i want to set the editor's textmode to multiline, but i dont' find any property in the ColumnUpdatingTextEditorOptions can be set, so I set the "textMode" to multiline when the "iggridupdatingeditrowstarted" event occured, but it is doesn't work.
The igTextEditor Known Issues have listed this issue:
  • When the base element is an INPUT element, setting the textMode option to multiline is not supported.
Is there any other  workaround ways to make the igEditor to support the multiline? When will the issue be fixed?
