2745
Column DataType Boolean - Change Combo Box Default Display Text
I have a grid with two columns that contain boolean data types.  When trying to edit the grid the allowable values are "true" and "false".  Our client would like to see "Yes" and "No" respectively.  Is there a template I can override to display different text instead of the default?
  • 30
    Display 'Yes' instead of 'true' for Boolean values igGrid combo using javascript
  • 2745
    Verified Answer
    Here was my solution:
    Razor:
    feature.Updating()
        .ColumnSettings(setting =>
            setting.ColumnSetting().ColumnKey("Id").Required(true).EditorType(ColumnEditorType.Combo).ComboEditorOptions(option =>
                option.AllowCustomValue(false).DataSource(Model.NewComboValues).EnableClearButton(false).TextKey("Key").ValueKey("Value").ValueKeyType(ComboDataType.Bool);
    Model:
    public KeyValuePair<string, string>[] NewComboValues
        get
            return new KeyValuePair<string, string>[]
                  new KeyValuePair<string, string>("Yes", Boolean.TrueString),
                  new KeyValuePair<string, string>("No", Boolean.FalseString)
    Everything works perfectly!
