On igPieChart drill down, if the next level contains single slice, then Chart is not completely visible in the browser window, the half part of the chart hides in the left corner of the window? The issue is with all browser types.
Hi, this was a known issue with the pie chart that has since been resolved. If you upgrade to the latest SR or VR you should see the issue is resolved.
Hi, jpavansharma
Could you give more details about how you update the data in the chart to display the next level? Post a code snippet if possible.
Cheers, Lazar
