@(Html.Infragistics().Combo().ID("controlID") .TextKey("Text") .ValueKey("Key") .SelectedIndexes(new [] {0}) .DataSourceUrl(Url.Action("Datasource", "Combo")) .Render())
When I run it on IE8, there will be a javascript error: 'undefined' is null or not a object. By the way, it works fine on firefox.
This error occurs in _dataChange function because this._dataSource is 'undefined':
_dataChange: function (q, z) { var l, H, F, E, m, G, s, t, r, w, k, A = this._lodWait, B = 1, u = -1, j = -1, D = this._needsSel, v = -1, y = this._keyVal, x = this._key, n = this._itemsHolder, p = this._dataSource, C = this.options;
Do you have any ieas?
Hello Jeff,Please let me know what is current status of the issue. Did you manage to resolve it?
Hello Jeff,I have tested the combo with the latest SR for 12.1 – 12.1.20121.2059 under IE 8 and I could not face any issue. I am attaching the sample which I used to test. The css and js folders and their content should be copied from C:\Program Files (x86)\Infragistics\NetAdvantage 2012.1\jQuery and the scripts are the same as C:\Users\Public\Documents\Infragistics\NetAdvantage 2012.1\jQuery\Samples\HTML\Demos\scripts
