I have a grid with a igCombo used to pick values for one of the columns. When I add or delete rows in the grid I need to refresh / rebind the combo to show the correct list. Is it possible to do this?
I have tried setting the datasource of the combo in the grid but the dropdown list does not change.
After updating the dataSource variable for the grid's combo I tried this:
var editor = $("#tbGridUserRoles").igGridUpdating("editorForKey", "FieldServiceCentreID");
$(editor).igCombo("selectedIndex", -1);
$(editor).igCombo("activeIndex", -1);
$(editor).igCombo("dataBind");
Doesn't work.
Have also tried this:
function refreshComboDataSource(columnKey, newDataSource) { var colSettings = $("#tbGridUserRoles").igGridUpdating("option", "columnSettings"); for (var i = 0; i < colSettings.length; i++) { if (colSettings[i].columnKey === columnKey) { if (colSettings[i].editorType && colSettings[i].editorType === "combo") { colSettings[i].editorOptions.dataSource = newDataSource; } $("#tbGridUserRoles").igGridUpdating("option", "columnSettings", colSettings); break; } } }
Doesn't work.Neither of these generate errors - they just dont change the contents of the combo when its clicked.
Any help appreciated.
There has been a few changes since 12.1. I am attaching an updated to 15.2 sample.
Hello ecatenate,
Thank you for your reply. Glad to help.
Please do not hesitate to contact me if you have any further questions regarding this scenario.
works a treat - thanks for your help.
Hi Simon,
My apologies. Attached is the correct sample. Notice that the button beneath the grid adds items to the editor's source.
Please let me know if this helps.
Thanks for responding Petar, however your sample does not demonstrate this.
The sample simply shows a grid binding to a datasource. Did you send me the wrong sample?
Regards, Simon
