I have a grid without paging. But when I send a request the URL has additional parameters that I dont know how to change/control like "top=5", and It gives me only five records when actually there are 7 or more. The service is used in other page with remote filtering so may be this "top=5" is making problem when I use it without paging, so the question is, how can I remove or change this parameter?
you can refer to this topic :
http://help.infragistics.com/Help/NetAdvantage/jQuery/2012.1/CLR4.0/HTML/igGrid_Paging.html
this paragraph in particular:
If you are binding to remote services, in order to properly initialize and render the pager, your service must specify both the responseDataKey (grid option) and the totalRecCountKey (paging option). The totalRecCountKey member tells the Paging widget how many records in total are in the backend. The responseDataKey specifies which property in the response contains the resulting data.
Therefore, when remote paging is used, the grid automatically generates the proper request parameters in the following way:
http://<server>/grid/PagingGetData?page=2&pageSize=25
