Hello, I would like to know who to add a link in a column with igHierarchicalGrid.
Can I add a parameter at the creation of the column ?
like :
{ headerText: "CLIENT", key: "nom", width: "150px", dataType: "string", link : "http://www.google.fr"},
Here my code :
$(window).load(function () {; $("#grid1").igGrid({ features: [ {name: "Paging",type: "local",pageSize: 10}, {name: "Sorting",type: "local"}, {name: "Filtering",type: "local"}, {name: "Resizing",allowDoubleClickToResize: true}, ], autoGenerateColumns: false, dataSource: 'popup_1.php?ind=<?php echo $_GET['ind']; ?>&pop=07', responseDataKey: 'records', initialDataBindDepth: -1, height: 500, width : 950, columns: [ { headerText: "CLIENT", key: "nom", width: "150px", dataType: "string"}, { headerText: "NB SOC", key: "nb_societes", width: "50px", dataType: "string" }, { headerText: "SD", key: "sd_validation", width: "50px", dataType: "string" }, { headerText: "SEGMENT", key: "entite_co_validation", width: "100px", dataType: "string" }, { headerText: "CONSEILLER", key: "co_validation", width: "150px", dataType: "string" }, { headerText: "ENTITE CLIENTELE", key: "entite_rc_validation", width: "100px", dataType: "string" }, { headerText: "RC", key: "rc_validation", width: "150px", dataType: "string" }, { headerText: "ENTITE", key: "rc_validation", width: "150px", dataType: "string" } ] }); });
I receive my dataSource from a php page, it's an array with json_encode().
Thanks for helping !
ps : sorry for my English, I'm Frensh
my headers :
<script src="../netadvantage/js/json2.js" type="text/javascript"></script><script src="../js/ParamsTab.js" type="text/javascript"></script><script src="../js/TableMaker.js" type="text/javascript"></script><link href="../netadvantage/themes/min/ig/jquery.ui.custom.min.css" rel="stylesheet" type="text/css" /><link href="../netadvantage/themes/base/ig.ui.min.css" rel="stylesheet" type="text/css" /><link href="../netadvantage/demos/content/style.css" rel="stylesheet" type="text/css" /><script src="../netadvantage/demos/scripts/modernizr-1.7.min.js"></script><script src="../netadvantage/demos/scripts/jquery.min.js" type="text/javascript"></script><script src="../netadvantage/demos/scripts/jquery-ui.min.js" type="text/javascript"></script><script src="../netadvantage/demos/scripts/jquery.tmpl.min.js" type="text/javascript"></script><script src="../netadvantage/js/combined/min/ig.ui.min.js" type="text/javascript"></script>
Hi Nikolay, hi Borislav,
Thank you for your reply.
I really do not understand why RowTemplate with condition not working, I get an error invalid property id js var $ = jQuery, call, _ = [], $ data = $ item.dat ...);} _.push ('</ a> </ td> </ tr>');} return _; My code:
rowTemplate: "<tr>" + "<td> <a href=\"BLOCKED SCRIPTself.close();window.parent.location='../vision/index.php?NIVEAU_V=2&societe=${NRID}'\"; >${NRID}</a></td> " "<td> {{if ${so0_libelle}=='CABINET GURTNER' }}${so0_libelle}{{else}}TOTO : ${so0_libelle}{{/if}}</td>" + "<td> ${so0_commune_insee}</td>" + "<td> ${so0_code_postal}</td>" + "<td> ${so0_sm}</td>" + "<td> ${so0_rc}</td>" + "<td> ${so0_conseiller}</td>" + "<td> <a href = \"BLOCKED SCRIPTvoid(0)\" onclick = \"window.location='popup15.php?nbOffre=${OFFRE}&societe=${NRID}'\";>${OFFRE}</a></td>" + "</tr>",if I try :
"<td> {{if 1==2 }}${so0_libelle}{{else}}TOTO : ${so0_libelle}{{/if}}</td>" +
It's work !
As soon as I put ${so0_libelle} in my condition, I get this error.
It seems to me that all the examples I've seen on the blog work like that.
Is something missing ?
Hello Stef,
I have created a support ticket on your behalf with number CAS-98159-C5F8V9. This case is linked with development issue # 118936 – “When autoGenerateColumns = TRUE and a row template is used, a column that contains only NULLs isn't displayed correctly”.
You can view its status by going to “Account > My Support Activity” on our website, selecting your case and clicking the "Development Issues" tab.
If you need more information, please feel free to contact us.
Hi Stef,
Please excuse me about the delay in my reply.I've attached an HTML sample demonstrating an igGrid with autoGenerateColumns and a row template which works.As you can see, you still need to point out the column's keys in the template - it's not possible to use column indices in such a situation I'm afraid.
I see the problem you've mentioned: when all of the values for a column are NULL, that column isn't displayed.(Note that this only happens when a row template is used).
I'll log this issue to our developers so it can hopefully be fixed for the next Service Release.
While you wait, I can recommend a workaround you can try while you wait: if possible, replace the NULLs with empty strings - that will be enough for the data binding to be successful.
Hope this helps,Borislav
Hello, I have a question, yet;) Is what I can put AutoGenerateColumns: true and add a template to my columns. Currently it does not work. I set AutoGenerateColumns: true because if I empty values column is deleted. Thank you for your help. Stef.
