505
How does the igUpload not allow extension work?
I am using igUpload control in my ASP.NET MVC3 project. I know it has a property allowedExtensions to set the allowed upload the files with these extensions, I want to know if there is a way to set some types of files cannot be uploaded, is there a property like notAllowedExtension? For example, I just do not want to user to upload .exe files, all other types are ok, how can I do that?
Best regards
Jason
  • 2426
    Suggested Answer
    Hi Jason,
    You can use the allowedExtensions option in JavaScript on the client or the AllowedExtensions method on the ASP.NET MVC helper:
    JavaScript - accepts an array of strings representing the allowed file extensions:
        $('#upload').igUpload({
            allowedExtensions: [ 'jpg', 'bmp' ],
            progressUrl: '/IGUploadStatusHandler.ashx'
    ASP.NET MVC Helper (Razor C#) - accepts a Generic List of strings representing the allowed file extensions:
        @(Html.Infragistics().Upload()
            .ID("upload")
            .AllowedExtensions(new List<string> { "jpg", "bmp" })
            .ProgressUrl("/IGUploadStatusHandler.ashx") .Render()
    If you would like to show an error message, you can handle the onError event in JavaScript and check for status code 2:
        $("#upload").bind("iguploadonerror", function (e, ui) {
            if (ui.errorCode === 2)
                alert(ui.errorMessage);
            return;
    You can read more about the upload's API in the API documentation: https://www.igniteui.com/help/igupload-igupload
    Hope that helps!
