115
igTextEditor, knockoutjs and custom bindings
Becuase IgTextEditor does not support knockoutjs, so i am writing custom bindings for the igtexteditor. Following is my code from the main file
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<title></title>
<script src="../scripts/infraguistics/js/jquery.min.js" type="text/javascript"></script>
<script src="../scripts/jquery-ui-1.8.20.min.js" type="text/javascript"></script>
<script src="../scripts/infraguistics/js/infragistics.loader.js" type="text/javascript"></script>
<script src="../scripts/infraguistics/js/infragistics.js" type="text/javascript"></script>
<script src="../scripts/infraguistics/js/modules/infragistics.util.js" type="text/javascript"></script>
<script src="../scripts/knockout-2.1.0.js" type="text/javascript"></script>
<script src="../scripts/CustomBindings.js" type="text/javascript"></script>
<link href="../css/structure/infragistics.css" rel="stylesheet" type="text/css" />
<script type = "text/javascript">
$(document).ready
function () {
var viewModel = function () {
this.userName = ko.observable("Daljit Singh");
ko.applyBindings(new viewModel());
$('#textEditor').igTextEditor({ width: 160 });
</script>
</head>
<body>
<input id="textEditor" data-bind = "executeOnLeave :userName" />
<input type = "text" data-bind = "value : userName" />
</body>
</html>
following is code of my CustomBindings.js, logic for my custom knockoutjs
/// <reference path="knockout-2.1.0.js" />
ko.bindingHandlers.executeOnLeave = {
init: function (element, valueAccessor, allBindingsAccessor, viewModel) {
var value = ko.utils.unwrapObservable(valueAccessor());
$(element).igTextEditor('text', value);
$('#textEditor').igTextEditor().live({ igtexteditorblur: function (evt, ui) {
var textVal = $('#textEditor').igTextEditor('text');
valueAccessor()(textVal);
//update the control when the view model changes
update: function (element, valueAccessor, allBindingsAccessor, viewModel) {
It works great, but i want to work this for all the all the igtexteditor controls. So I thought I will change, '#textEditor' to $(element). $(element) works for getting and setting text value, but it does not work for assign blur event.
Any help will be appreciated.
  • 23953
    Suggested Answer
    Hi Daljit Singh,
    Sorry for the late answer.
    Attached you can find working sample on igTextEditor integration with KnockoutJS. I simply reused your code and made couple of changes.
    The first change is that I moved igTextEditor initialization before KnockoutJS model binding. Here is the code:
    Code Snippet
    1. $.ig.loader(function () {
    2.     // Initialize igTextEditor before KnockoutJS
    3.     $('#textEditor').igTextEditor({ width: 160 });
    4.     $('#textEditor1').igTextEditor({ width: 160 });
    5.     var viewModel = function () {
    6.         this.userName = ko.observable("Daljit Singh");
    7.         this.userName2 = ko.observable("Daljit Singh2");
    8.     };
    9.     ko.applyBindings(new viewModel());
    10. });
    Second, I changed the way binding to igTextEditor blur event is done. I used bind. In the bind function I get the value of the igTextEditor from the ui parameter of the function (For some reason  $(element).igTextEditor("text") didn't return the correct value.)
    Here is the code:
    Code Snippet
    1. init: function (element, valueAccessor, allBindingsAccessor, viewModel) {
    2.     var value = ko.utils.unwrapObservable(valueAccessor());
    3.     $element = $(element);
    4.     $element.igTextEditor('text', value);
    5.
    6.     $element.bind("igtexteditorblur", function(evt, ui) {
    7.         // Get the value of the text editor from the ui parameter
    8.         var textVal = ui.owner.element.igTextEditor('text');
    9.         valueAccessor()(textVal);
    10.     });
    11.
    12. }
    Hope this helps,
    Martin Pavlov
    Infragistics, Inc.
    igTextEditor_knockout.zip
  • 115
    Do no body know how to fix it
