185
comboeditor not shown on igGrid when using infragistics.loader.js
Hello.
I´m using Infragistics.Web.Mvc version 3.12.1.2023
My references
<script src="@Url.Content("~/Scripts/IG/infragistics.loader.js")" type="text/javascript"></script>
I have troubles when the user try to edit a row, specifically when they try to edit options in the comboeditor. The comboeditor never shows.
and I can see in Firebug  the message: 'In order to use the combo type for ui.igGrid, the ui.igCombo should be loaded'
I´m loading resources in this way:
@(Html.Infragistics().Loader()
.ScriptPath(Url.Content("~/Scripts/IG/"))
.CssPath(Url.Content("~/Content/css/"))
.Render()
@( Html.Infragistics().Grid<BoletaDetalleView>()
.ID("igGridDetalle")
.Columns(column =>
column.For(x => x.ID).DataType("int").HeaderText("ID").Hidden(true);
column.For(x => x.ApellidoNombre).DataType("string").HeaderText("Apellido Nombre").Width("50%");
column.For(x => x.CUIL).DataType("int").HeaderText("CUIL").Width("20%");
column.For(x => x.MotivoBajaDescripcion).HeaderText("Motivo Baja").Width("20%");
column.For(x => x.Remuneracion).DataType("number").HeaderText("Remuneracion").Width("10%");
column.For(x => x.AfiliadoId).DataType("int").Hidden(true);
column.For(x => x.PersonalId).DataType("int").Hidden(true);
column.For(x => x.BoletaId).DataType("int").Hidden(true);
column.For(x => x.MotivoBajaId).DataType("int").Hidden(true);
.Features(features =>
features.Sorting().Mode(SortingMode.Single).ColumnSettings(settings =>
settings.ColumnSetting().ColumnKey("ID").AllowSorting(true);
features.Selection().MouseDragSelect(true).MultipleSelection(false).Mode(SelectionMode.Row);
features.Updating().ColumnSettings(settings =>
.ColumnKey("MotivoBajaDescripcion")
.Required(false)
.EditorType(ColumnEditorType.Combo)
.ComboEditorOptions(options =>
options.TextKey("Descripcion");
options.ValueKey("ID");
options.DataSource(ViewBag.MotivosBaja);
options.DropDownMinHeight(200);
.ClientDataSourceType(ClientDataSourceType.JSON)
.DataSource(new List<BoletaDetalleView>().AsQueryable())
.Width("100%")
.LocalSchemaTransform(true)
.AutoCommit(true)
.DataBind()
.Render()
Thanks in advance
  • 23953
    Verified Answer
    igCombo is not loaded automatically by igGridUpdating, so you should reference it manually.
    Your loader initialization code should look like this one:
    Code Snippet
    1. @(Html.Infragistics().Loader()
    2. .ScriptPath(Url.Content("~/Scripts/IG/"))
    3. .CssPath(Url.Content("~/Content/css/"))
    4. .Resources("igCombo")
    5. .Render()
    6. )
    Best regards,
    Martin Pavlov
    Infragistics, Inc.
