hello,
I tried this example with cshtml and it worked:
http://blogs.infragistics.com/blogs/taz_abdeali/archive/2011/05/09/using-netadvantage-jquery-grid-in-asp-net-mvc.aspx
Then I found this one for razor-vbhtml, which I#m using.
http://blogs.infragistics.com/blogs/robert_richard/archive/2012/01/13/using-vb-net-razor-markup-with-the-infragistics-jquery-grid.aspx?CommentPosted=true#commentmessage
however, this example did not work.
do you also provide this example as vbhtml, so I could see what the problem is ...
The code in the view shows several errors, Model not defined, URL not defined etc.
Thanks in advance !
Hello Tobias,
I am just to see if you if you need any further assistance with this matter.
Hi Fernando,Please check out Tsvetelina's post above Bhadresh's - quote:We still do not have razor-vbhtml Views in our sample browser and I hope that soon there will be.
You can find a running sample attached to the forum thread below:http://community.infragistics.com/forums/p/68393/346551.aspx#346551
Here is the direct link:http://community.infragistics.com/cfs-file.ashx/__key/CommunityServer.Discussions.Components.Files/589/5023.HierarchicalDatagridInfragisticsJQuery.zipIn the future we might put up full samples of the igGrid (and other controls based on interest) in the Infragistics GitHub repository that was created a couple of weeks ago, but I cannot promise anything certain at the moment.Such samples can also be provided by members of the forums as well so that more real-life scenarios are uploaded.Hope this helps you out for the time being.Cheers,Borislav
Hi!
I am trying to get a very simple sample of igGrid, but "complete" code. I didn't find anything yet. Also, the sample in the link below doesn't work for NetAdventage 2012.v1
thanks,
Fernando
I am just following up to see if you need any assistance with this matter.
Thank you for your interest in our jQuery components.
I also read your post in other forum thread:
http://community.infragistics.com/forums/p/71070/359749.aspx#359749
Currently our jQuery grid supports filtering and editing. If by scrolling you mean "Virtual Scrolling" , this is backlog item for our future releases.
At the moment only visualization is supported
http://help.infragistics.com/NetAdvantage/jquery/2012.1?page=igGrid_Virtualization.html
Hope this helps.
