Currently trying out the igTemplating engine, and I wondered if it is possible to use javascript expressions on property values, e.g. ${myProperty.replace('a', 'b')}.
This was a nice feature in the jQuery template engine ...
Hi there,
Unfortunatelly this has to be performed externally on the data, because the Infragistics templating engine does not support such functional evaluation inside the substitution tokens. At this point the functional scope of the substitution tokens is data extraction from JSON array/object, however it does not cover function evaluation.
Thank you for using the Infragistics forums!
