695
Not able to bind to grid
WCF webservice returning JSON Sting to UI, I am able to see data in browser, but not able to bind to grid. It is working if i assigned to string and bind to grid.
Code below :
<script id="JsonDataTemplate" type="text/x-jquery-tmpl">
        <tr> <td> ${Description} </td> <td></tr>
 </script>
 $.ig.loader({
            scriptPath: '../../js/',
            cssPath: '../../css/',
            resources: 'igDataSource'
 $.ig.loader(function () {
            BindJson();
function BindJson() {
            $('table thead').html("<tr><th>Applies To</th></tr>");
            var jsonSchema = new $.ig.DataSchema("json", { fields: [
       {name: "Description", type: "string" } ]
            url = "http://localhost:4293/DealService.svc/Get_data"; // Returning JSON String : [{ "Description": "Mock subject", "Id": 242, "Notes": "" }]
           // ds = new $.ig.DataSource({ dataSource: url, schema: jsonSchema, responseDataType: "json" });   tried but not working
            ds = new $.ig.DataSource({dataSource: url}); //tried not working
            // ds  = new $.ig.JSONDataSource({ dataSource: categoriesWithProducts, responseDataKey: "d" });  tried not working
           // ds = new $.ig.DataSource({ dataSource: jsonData });  Working with local JSON string
            ds.dataBind();
            $("#t1 tbody").empty();
            $("#JsonDataTemplate").tmpl(ds.dataView()).appendTo("#t1 tbody");
 jsonData = [{ "Description": "Mock subject"}];
Can you please let me know. Thanks
  • 19693
    Verified Answer
    Hello InfraOracle ,
    The issue, that you are experiencing, happens because the databinding is still not completed when you append the dataView .
    For the purpose you do this in the callback function when data binding is complete.
    $.ig.loader().load("igGrid.*,igDataSource,igShared,igTemplating",
            function () {
                rowTemplate = "  ${ProductID}   ${Name}   ${ProductNumber} ${StandardCost}";
                url = "http://localhost:2880/AdventureWorksService.svc/Product?$format=json";
                    type: "remoteUrl",
                    dataSource: url,
                    responseDataKey: "d",
                    fields: [
                        { name: "ProductID", type: "number" },
                        { name: "Name", type: "string" },
                        { name: "ProductNumber", type: "string" },
                        { name: "StandardCost", type: "number" }
                    callback: function (success, error) {
                        if (success) {
                            $("#JsonDataTemplate").tmpl(ds.dataView()).appendTo("#table1");
                        } else {
                            alert(error);
                ds.dataBind();
    Please take a look at the help article regarding this :
    http://help.infragistics.com/NetAdvantage/jquery/2012.1?page=igDataSource_Getting_started_with_igDataSource_and_WCF.html
    More for the igDataSource options you can find in the API documentation:
    http://help.infragistics.com/jQuery/2012.1/ig.DataSource#options
    Hope this helps.
