300
Deleting row with row selection on
I have enabled delete row and I also have row selection turned on.  The problem is when i click the dlete the row selectionChanging function fires and the delete never happens.  Is there a workaround for this.  I have this same problem when i put links in my grid.  if i click a link the rowSelectionChanging will fire.
Sy
Here is my grid.
template = "<tr><td> <img alt='' src='" + data.imagePath + "${CatID}" + ".jpg'' /> <p><a href='" + data.imagePathLarge + "${CatID}" + ".jpg' class='pzoom'>Zoom</a></p> </td> <td> ${CatID} </td> <td> ${Name} </td> <td> ${CreatedBy} </td> <td> ${QuantityOfItems} </td> <td> ${CreatedDateTime} </td><td> ${ExpirationDate}</td><td> ${PublishDate}</td></tr>";
            tablecolumns = [{ headerText: "Image", key: "Name", dataType: "string", width: "75" }, { headerText: "Catalog ID", key: "CatID", dataType: "string", width: "100" }, { headerText: "Name", key: "Name", dataType: "string", width: "200" }, { headerText: "Created By", key: "CreatedBy", dataType: "string", width: "100" }, { headerText: "Item Count", key: "QuantityOfItems", dataType: "number", width: "75" }, { headerText: "Created", key: "CreatedDateTime", dataType: "date", width: "75" }, { headerText: "Expiration", key: "ExpirationDate", dataType: "date", width: "100" }, { headerText: "Published", key: "PublishDate", dataType: "date", width: "100"}];
            $("#catalogsearch").igGrid({
                autoGenerateColumns: false,
                rowTemplate: template,
                columns: tablecolumns,
                jQueryTemplating: true,
                dataSourceType: 'json',
                dataSource: data.json,
                width: '100%',
                height: '100%',
                features: [
                type: 'local',
                pageSize: 100
                type: "local"
                mode: 'row',
                rowSelectionChanging: function (ui, args) {
                    var col = document.getElementById("catalogsearch_CatID").cellIndex;
                    var row = $("#catalogsearch").igGrid('activeRow');
                    var cell = $("#catalogsearch").igGrid('cellAt', col, args.row.index);
                    if (debug) {
                        console.log('rowSelectionChanging event fired. Row Index = ' + args.row.index + '-' + $(cell).text());
                    window.open('../dashboard/catalogbuilder.aspx?id=' + $(cell).text(), '_self', false);
                enableAddRow: false,
                editMode: 'none',
                enableDeleteRow: true,
                // event raised before row was deleted
                rowDeleting: function (evt, ui) {
                    var answer = confirm("Are you sure you want to delete this catalog?");
                    if (answer) {
                        try {
                            showLoader("Deleting Catalog..."); //Loader hidden in comm_findproduct_trackSuccess()
                        } catch (error) {
                            if (debug) {
                                console.log("showLoader() error: " + error.description);
                        simpleLoad('../clientadmin/stats.aspx/deleteCatalog', { CatID: $(cell).text() }, function (data) {
                            if (data.success) {
                                alert("Catalog Deleted");
                            } else {
                                alert("There was a problem deleting the catalog");
                    try {
                        hideLoader(); //Loader shown in find_product()
                    } catch (error) {
                        if (debug) {
                            console.log("hideLoader() error: " + error.description);
                // event raised after row was deleted
                rowDeleted: function (evt, ui) {
                    //                    var cell = $("#b2busers").igGrid('cellAt', 0, ui.rowID);
                    //                    console.log("rowDeleted event fired. Row Index = " + ui.rowID + '--cellValue = ' + $(cell).text());
                type: "local",
                filterDropDownItemIcons: false,
                filterDropDownWidth: 200
                columnSettings: [
                        columnsettings: "CreatedDateTime",
                        isGroupBy: true,
                        dir: "asc"
