505
selectionChanged event is not fired when set selectedIndex
I am using igCombo in an ASP.NET MVC3 project, I found that the selectionChanged event is not fired when set selectedIndex.
I used it like:
$("#comboCompanies").igCombo(
                selectionChanged: function (evt, ui) {
                    var selectedId = ui.items[0].value;
                    DoSomething();
$("#comboCompanies").igCombo("selectedIndex", 2);
If the selection is made by the UI (I mean select option with mouse click), the selectionChanged will be fired.
But if I set the selection in code, the event won't be fired. Why?
  • 2735
    Verified Answer
    Hi, Jason,
    You have to bind events in ASP.NET in this way:
    $("#combo").igCombo({
                        dataSource: colors,
                        textKey: "Name",
                        valueKey: "Name",
                        width: "200px",
                        autoComplete: true
    $(document).delegate("#combo", "igcomboselectionchanged", function (evt, ui) {
                        var selectedId = ui.items[0];
                        console.log(selectedId.value);
    In order to trigger this event you have to set third parameter fire to true $("#combo").igCombo("selectedIndex", 2, true);
    Related topics:
    http://help.infragistics.com/NetAdvantage/jQuery/Current/CLR4.0?page=igCombo_Configure_Selection.html
    http://help.infragistics.com/jQuery/2012.1/ui.igCombo#!methods
    Stanimir Todorov
