How to render multiple charts in a loop, something as shown below:
foreach (DataSeries dataSeries in dataSeriesCollection){<fieldset>@(Html.Infragistics().DataChart(dataSeries.AsQueryable()).ID("chart").VerticalZoomable(true).HorizontalZoomable(true).Axes((axes) =>{axes.NumericX("xAxis");axes.NumericY("yAxis");}).Series(series =>{series.Scatter("scatterSeries").XAxis("xAxis").YAxis("yAxis").XMemberPath(dataPoint => dataPoint.X).YMemberPath(dataPoint => dataPoint.Y);}).DataBind().Render())</fieldset>}
It looks like only a single chart is getting rendered with all series data.
Sample app is here https://www.dropbox.com/s/bts9r7gxxy5npws/Test.zip.
Plz help.
Hi, sanjaysutar
Actually, that way you are going to generate multiple charts (and if you apply the chart element ID fix my colleague suggested above). To have multiple series in a single chart you need to define multiple chart series in the Series(series => { ... }) function call in the MVC helper. You need to have something like this:
Cheers, Lazar
You have to generate and set unique ID for every chart. In you sample, you set foreach chat same ID.
@(Html.Infragistics().DataChart(dataSeries.AsQueryable()).ID("chart_" + RandomNumber).VerticalZoomable(true)
Stanimir Todorov
