Hi there.
Whenever I filter using the simple filtering feature, on a date using the following conditions:
Today, Yesterday, This Month, Last Month, Next Month, This Year, Last Year and Next Year
The filter condition menu gets disabled and prevents the user from changing the filter condition.
Hi Christoff,Actually it's a by-design situation: the filtering conditions you mentioned are unary (meaning that there is no explicit filtering value - an implicit one is used instead); the same happens when you try to apply filtering on a Boolean-valued column.
