1845
Select item by value
Has anyone had to set the selected item by value?  There's an "itemByValue" method, but it returns a Jquery object, no index.  The only method that I see for setting the current item, "selectedIndex", only accepts an index as an argument.
I could probably use Jquery to find the index by finding the corresponding value in the DOM, but I don't want to if there's a more elegant way.
  • 2735
    Verified Answer
    Hi JoshNoe,
    The method itemByValue return object with properties - element, index, text and value. So, you can accomplish your task with this snippet:
    HTML Code:
    <select id="comboColors">
                                    <option value="blackVal">Black</option>
                                    <option value="blueVal">Blue</option>
                                    <option value="brownVal">Brown</option>
                                    <option value="greenVal">Green</option>
                                    <option value="orangeVal">Orange</option>
                                    <option value="purpleVal">Purple</option>
                                    <option value="redVal">Red</option>
                                    <option value="whiteVal">White</option>
                                    <option value="yellowVal">Yellow</option>
                                </select>
    JavaScript Code:
    var item = $("#comboColors").igCombo("itemByValue", "orangeVal");
    $("# comboColors").igCombo("selectedIndex", item.index);
    Stanimir Todorov
