20
CSS File Crashes VS 2010 Ultimate
Hello All,
I'm trying to open " ig.ui.min.css " in the VS 2010 Ultimate environment. Each time I do, it crashes. This is particularly troublesome because it affects project/solution wide text searches as well.
Any guidance is greatly appreciated.
  • 12679
    Suggested Answer
    Hello @johnyl1968,
    I'm not sure if we can do anything about this, probably you can try to open the file with notepad++ or any other lightweight editor. I've opened the file with VS Ultimate and it's true that the IDE froze for a while but I was able to open the file without  problems.
