254
Submitting With 'Enter' Key
How can I submit a form that contains igTextEditors when I press the 'Enter' key on any of the fields in the form? Like for a Login page.
I am using jquery 1.7.1, and I have tried lot of code combinations. Using both ".delegate", ".on" (since .delegate is deprecated on 1.7). Binding to keypress works for all the keys except the enter key.
I have also used the sample you guys provide and nothing. Not even alphabetic keys.
$(document).delegate("#UserName", "igtexteditorkeypress", function (evt, ui) {....
PS. I will also be using this process to do jquery ajax requests to the server (for search), so I will need the binding to work even without the default form behavior.
Any help is appreciated.
Thank You
