75
Rowtemplate columns hidden
Hi... how can I generate a rowtemplate with a column hidden? That column will have the PrimaryKey of the table.
My code is omething like this
@( Html.Infragistics().Grid<Feed>()
        .ID("grdFeeds")
        .UpdateUrl("EditingSaveChanges")
        .PrimaryKey("ID")
        .AutoGenerateColumns(false)
        .AutoCommit(true)
        .JQueryTemplating(true)
        .RowTemplate("<tr><td>${ID}</td><td>${Nombre}</td><td>${Letras}</td><td>${RutaIn}</td><td>${RutaOut}</td></tr>")
        .Columns(column => {
                                column.For(x => x.ID).HeaderText("ID").Hidden(true);
                                column.For(x => x.Nombre).HeaderText("Name");
                                column.For(x => x.Letras).HeaderText("Letters");
                                column.For(x => x.RutaIn).HeaderText("In Folder");
                                column.For(x => x.RutaOut).HeaderText("OutFolder");
        .Features(features =>
            features.Filtering();
            features.Paging().PageSize(20).PrevPageLabelText("Previous").NextPageLabelText("NEXT").ShowPageSizeDropDown(false).ShowPagerRecordsLabel(false);
            features.Selection().MouseDragSelect(true).MultipleSelection(true).Mode(SelectionMode.Row);
            features.Sorting().Mode(SortingMode.Single);
            features.Selection().Mode(SelectionMode.Row).MultipleSelection(false);
            features.Updating().EnableAddRow(false).EditMode(GridEditMode.None);
        .DataSourceUrl(Url.Action("GetFeeds"))
        .Width("100%")
        .Height("500px")
        .DataBind()
        .Render()
but its rendering like
  • 23953
    Suggested Answer
    You can try to set display style to none for this column.
    Your row template string should look like this:
    Code Snippet
    1. RowTemplate("<tr><td style='display: none'>${ID}</td><td>${Nombre}</td><td>${Letras}</td><td>${RutaIn}</td><td>${RutaOut}</td></tr>")
    However this approach doesn't seem to work in Firefox(10.x.x).
    I assume that you want to use ID column in your code. If that is the case there is a better solution.
    When you set primaryKey property (PrimaryKey("ID")) igGrid adds "data-id" attribute to each row which value is set to the ID column value. ( Note: you don't need to define ID column in columns array.)
    Now you can get the ID value in jQuery like this:
    var id = $(row).attr("data-id"); where row is DOM element.
    The following code gets ID column for selected rows:
    Code Snippet
    1. function getSelectedRows() {
    2.     var rows = $('#grid1').igGridSelection('selectedRows');
    3.     $.each(rows, function (i, row) {
    4.         var rowId = $(row.element).attr("data-id");
    5.     });
    6. }
    Hope this helps,
    Martin Pavlov
    Infragistics, Inc.
  • 24671
    hi,
    if you want to hide a column when using row templating, you shouldn't include it in the template string. When rowTemplate is set, it is not compatible with column hiding.
    Angel
