Is there a good way to refresh the summary of a column while updating the column? Actually I want to use batch updating on my grid. When the data load on first time the summary looking good but after modification operation no effect occurred on summary field.
Hi Alexander, I have a similar problem. I set the value of the cell on the event editCellEnded. However summaries does not update accordingly to the change even though autoCommit is set to true.
Thank you sir you have done it.
I think the confusion comes from the fact that you have autoCommit: false in the grid options (which is the default value, therefore if you edit, without committing manually, the data source on the client never gets updated, therefore summaries doesn't intercept the change and doesn't update its values.
If you set autoCommit to true, summaries will automatically update after some cell/ row values change.
Hope it helps. Thanks,
Angel
