I have an igGrid that has a JSON array as its datasource. The JSON array data comes from an ajax call to a webservice. The grid works and returns the data I'm expecting, but when the grid is loaded, it looks like all the data is loading to the client in one burst. I have about 10,000 records that I'm expecting from my webservice. I have paging turned on to show 20 records/page.
How do I configure the grid so only 20 records are retrieved initially, then as I page or use the filter, additional records are retrieved from the datasource so the load times are faster? Here's my grid setup. I also tried changing the "mode" to remote for paging & filtering, but that seems to break the paging & filtering altogether.
$.ajax({ type: "POST", url: "Services/TextileService.asmx/GetAllTextiles", data: {}, contentType: "application/json; charset=utf-8", dataType: "json", traditional: true, success: function (data) { $("#grid2").igGrid({ autoGenerateColumns: false, columns: [ { headerText: "Pattern", key: "Pattern", dataType: "string" }, { headerText: "Colorway", key: "Colorway", dataType: "string" }, { headerText: "Mill", key: "Mill", dataType: "string" }, { headerText: "Grade", key: "Grade", dataType: "string" }, { headerText: "PartID", key: "PartID", dataType: "string" }, { headerText: "Obsolete", key: "Obsolete", dataType: "string" }, { headerText: "Class", key: "Class", dataType: "string" } ], width: "100%", dataSource: data.d, responseDataKey: "Records", tabIndex: 1, primaryKey: "PartID", fixedHeaders: true, autoAdjustHeight: false, features: [ { name: "Filtering", type: "local", dataFiltering: filteringHandler, allowFiltering: true, caseSensitive: false, columnSettings: [ { columnKey: "Pattern", allowFiltering: true, condition: "contains" }, { columnKey: "Colorway", allowFiltering: true, condition: "contains" }, { columnKey: "Mill", allowFiltering: true, condition: "contains" }, { columnKey: "Grade", allowFiltering: true, condition: "contains" }, { columnKey: "PartID", allowFiltering: true, condition: "contains" }, { columnKey: "Obsolete", allowFiltering: true, condition: "contains" }, { columnKey: "Class", allowFiltering: true, condition: "contains" } ] }, { name: "Sorting", type: "local", //mode: "multi", columnSettings: [ { columnKey: "Pattern", allowSorting: true, currentSortDirection: "asc", firstSortDirection: "asc" }, { columnKey: "Colorway", allowSorting: true, currentSortDirection: "asc", firstSortDirection: "asc" }, { columnKey: "Mill", allowSorting: true, firstSortDirection: "asc" }, { columnKey: "Grade", allowSorting: true, firstSortDirection: "asc" }, { columnKey: "PartID", allowSorting: true, firstSortDirection: "asc" }, { columnKey: "Obsolete", allowSorting: true, firstSortDirection: "asc" }, { columnKey: "Class", allowSorting: true, firstSortDirection: "asc" } ] }, { name: "Selection", mode: "row", rowSelectionChanging: rowSelectionHandler, multipleSelection: false, activation: true }, { name: 'Paging', type: "local", pageSize: 20, visiblePageCount: 5, totalRecCountKey: "servertotalcount" } ] }); }, failure: function (data) { alert("ERROR: GetAllTextiles"); } });
John
Hello nguyenjn ,
Thank you for the update.
I created a simple sample of iGrid that calls a regular asmx webservice and binds json data
As Angel mentioned you should set ResponseFormat
Please refer also to the below article for returning JSON when using ASMX services
http://encosia.com/asmx-scriptservice-mistakes-installation-and-configuration/
Let me know if you need further assistance
I asked DS to create a sample for you which binds to ASMX. we have a couple of remote binding samples for client only grids (no MVC) but they are binding to WCF instead of ASMX. In theory it shouldn't make a difference.
The grid always performs a GET request when data-binding, so i suggest to double check if you have the GET methods which return JSON exposed (not only the POST ones).
that should do it:
[WebMethod]
[ScriptMethod(UseHttpGet=true, ResponseFormat=ResponseFormat.Json)]
Let me know if it helps.
Angel
I still have the issue.
The issue is how do I get my asmx web service to return json instead of xml. When I call the web service using the JQuery $ajax POST, it works great and returns json data and the grid populates. But when I click next/prev on the igGrid pager, it uses a GET so when it calls the web service something different is happening and the same web service is returning xml.
I'm not instantiating a separate igDatasource. When I instantiate my igGrid, I'm assuming it will instantiate an igDataSource for me and as long as I set the "dataSourceType" attribute to json, it'll expect json format in the data, correct?
Do you have any example code that uses a remote (i.e. not local) datasource for paging or filtering and calls a regular asmx webservice and returns json data?
I am just checking about the progress of this issue.
Let me know if you need further assistance.
Hello ,
You receives this error because your dataSourceType is xml and you are setting it to json
http://help.infragistics.com/jQuery/2011.1/ui.iggrid#!options
You can use igDataSource in order to bind the igGrid to it
https://www.igniteui.com/help/igdatasource-igdatasource-overview
