224
Row and Column highlighting
Is there a way to highlight a specific row or column?
When highlighting a row, I'd like to highlight it depending on a cell value. For instance if there is a 'colour' column, I'd like to show the entire row in that colour.
When highlighting a column, I'd like to highlight it when a filter is set. It is difficult to see when a filter is set, so to make it more clear to the user, I'd like to highlight the entire column.
cheers.
  • 2225
    We're doing something like this as well.
    I don't know if this will fit your requirements, but one way of doing this is by using Row Templating. With it you can apply conditional styles to the row based upon a field value.
    A tutorial by Taz Abdeali can be found here:
    http://blogs.infragistics.com/blogs/taz_abdeali/archive/2011/04/21/jquery-templating-tips-amp-tricks.aspx
  • 24671
    Here is one possible solution:
    $("#yourGrid").bind({
    mousemove: function (e) {
    var row = $(e.target).closest("tr");
    // check criteria
    row.children().addClass("my special class");
    mouseout: function (e) {
    // find the TR again, and remove the classes from the cells ,  if applied
  • 19693
    Hello jbergenthal ,
    You can iterate through the rows and cells of the igGrid and checking if the value is equal to the criteria
    function on_Click() {
                var criteria = $('#criteria').val();
                $("#grid1").igGrid('rows').each(function (index) {
                    var row = $("#grid1").igGrid("rowAt", index);
                    $(row.cells).each(function (i) {
                        var cell = $("#grid1").igGrid('cellAt', i, index);
                        var cellText = $(cell).text();
                        if (cellText == criteria) {
                            $(cell).css("color", "#FF0000");
                            $(row).css("background-color", "#FF0000");
      <input type="text" id="criteria" />
      <input type="button" value="Color a cell" id="button1" onclick="on_Click();" />
    For more information regarding the styling please refer to the below article
    http://help.infragistics.com/NetAdvantage/jQuery/Current/CLR4.0?page=igGrid_Styling_and_Theming.html
    You can see the CSS classes regarding the filtering
    http://help.infragistics.com/jQuery/2011.1/ui.iggridfiltering#!theming
    Let us know if you need further assistance.
