A minor UI issue (CSS issue):
In the grid, the triangle icon for Previous Page is located to the right under/over the "Prev" text. This is also showing up in the samples for paging.
Hello Tony,
Thank you for the clarification regarding the browser's version.
I will report this as development issue in IE7.
Thank you for using jQuery toolset
It works fine in IE 8 and 9. However, in IE7 the image doesn't align. Sorry I didn't mention that sooner. I guess at some point I had set the document mode for something else before navigating to your samples site.
IE 7 support is important because many of our customers will be accessing the site through the web browser control (Microsoft) which is effectively IE7. We are looking into our options for updating a registry entry so that the control uses the latest browser engine on the client instead of the default of IE7, but I'm not sure where that stands or when it will happen.
Thank you for reporting this.
Can you please let us know which browser and version did you use to encounter the issue?
Which version of jquery and Infragistics.Web.Mvc.dll are you using ?
I was not able to reproduce the issue with the online sample using IE9 and FF5
http://samples.infragistics.com/jquery/grid/paging-api
Hope hearing from you
