Hello
I'm trying to solve a problem in igGrid. The problem is...
1. There are multiple columns that can make side scroll.
2. Pull the scroll right to see the rightmost column.
3. Select the rightmost column and click "Move left" button.
4. Column moves to a row to the left(this is not the problem) but the scroll moves to the far left, regardless of where my selected column is.
What I want is to fix the scroll on the column I moved. Or at least, I want A NOT MOVING SCROLL.
Please let me know if there is a workaround for this problem.
Looking forward to your support!
Thanks and regards!
Thank you for the post.
I guess this is a duplicated inquiry with Problem in igGrid when I move a column (IgniteUI 2021) | Infragistics Forums, so we'd like to assist you there, not here.
Thank you in advance.
