15
Unable to bind child layout to the dataset that is loaded on demand in igHierarchicalGrid
We are trying to implement late binding for child layout of parent in igHierarchicalGrid when the parent row is expanded. We have some hard time to get it to work. The child rows are simply not showing. Please help!!!
Example code:
$('#SalesforceProcessesGrid').igHierarchicalGrid({
initialDataBindDepth: 0,
dataSource: vm.Processes,
height: "600px",
autoGenerateColumns: false,
autofitLastColumn: false,
primaryKey: 'sf_process_master_id',
autoCommit: true,
renderCheckboxes: true,
caption: 'Processes',
columns: [
{ headerText: "Process ID", key: "sf_process_master_id", dataType: 'number', hidden: true },
{ headerText: "Process", key: "sf_process_ty", dataType: "string", width: "14%" },
{ headerText: "Start Dt", key: "process_start_dt", dataType: "string", width: "12%" },
{ headerText: "User", key: "process_start_user", dataType: "string" },
{ headerText: "Workorder", key: "crit_workorder", dataType: "string" },
{ headerText: "Job IDs", key: "crit_job_ids", dataType: "string" },
{ headerText: "Account Ty", key: "crit_account_ty", dataType: "string" },
{ headerText: "Kill Process ID", key: "crit_process_id", dataType: "number" },
{ headerText: "Has Error", key: "error_ind", dataType: "bool" },
{ headerText: "Error Message", key: "error_msg", dataType: "string" },
{ headerText: "Retry #", key: "process_attempt_cnt", dataType: "number", format: '###,###,###', columnCssClass: 'alignR' },
{ headerText: "Completed", key: "sf_batch_completed_ind", dataType: "bool" },
{ headerText: "Completed Dt", key: "sf_batch_completed_dt", dataType: "string", width: "12%" }
features: [
{ name: 'ColumnMoving', moveType: 'render' },
{ name: 'Resizing' }, { name: 'Hiding' },
{ name: 'Sorting' },
{ name: 'Paging', type: "local", pageSize: 50, pageSizeDropDownLocation: 'inpager' },
allowFiltering: true,
caseSensitive: false
rowExpanding: function (evt, ui) {
var parentRow = ui.parentrow;
var parentRowId = parentRow.attr("data-id");
var res = GetSalesforceProcessesByProcessMasterId(parentRowId);
var processItems = res.Items;
//??? not working
parentRow.childrenData = processItems;
columnLayouts: [
key: 'Items', autoGenerateColumns: false, primaryKey: 'sf_process_item_id', autofitLastColumn: false, renderCheckboxes: true,//caption: 'Items',
columns: [
{ headerText: 'sf_process_item_id', key: 'sf_process_item_id', dataType: 'number', hidden: true, headerCssClass: 'xSmallFont' },
{ headerText: 'Start Dt', key: 'sf_process_item_created_dt', dataType: 'string', width: "10%", headerCssClass: 'xSmallFont' },
{ headerText: "User", key: "sf_process_item_created_user", dataType: 'string', headerCssClass: 'xSmallFont' },
{ headerText: 'Process Key', key: 'sf_process_item_key', dataType: 'string', width: "10%", headerCssClass: 'xSmallFont' },
{ headerText: 'SF Object Name', key: 'sf_object_nm', dataType: 'string', width: "12%", headerCssClass: 'xSmallFont' },
{ headerText: "SQL Retreived", key: "sql_records_retrieved", dataType: 'number', format: '###,###,###', columnCssClass: 'alignR', headerCssClass: 'xSmallFont' },
{ headerText: 'SQL-Records Retreived Dt', key: 'sql_records_retrieved_dt', dataType: 'string', width: "10%", headerCssClass: 'xSmallFont' },
{ headerText: 'SF Total Pushed', key: 'sf_total_processed', dataType: 'number', format: '###,###,###', columnCssClass: 'alignR', headerCssClass: 'xSmallFont' },//
{ headerText: "SF Total Pushed Dt", key: "sf_total_processed_dt", dataType: 'string', width: "10%", headerCssClass: 'xSmallFont' },
{ headerText: 'SF Total Success', key: 'sf_total_success', dataType: 'number', format: '###,###,###', columnCssClass: 'alignR', headerCssClass: 'xSmallFont' },
{ headerText: 'SF Total Failed', key: 'sf_total_failed', dataType: 'number', format: '###,###,###', columnCssClass: 'alignR', headerCssClass: 'xSmallFont' },
{ headerText: "SF Ids Returned", key: "sf_ids_returned", dataType: 'number', format: '###,###,###', columnCssClass: 'alignR', headerCssClass: 'xSmallFont' },
{ headerText: 'SF Ids Returned Dt', key: 'sf_ids_returned_dt', dataType: 'string', width: "10%", headerCssClass: 'xSmallFont' },
{ headerText: "SQL-SF IDs Updated", key: "sql_ids_updated", dataType: 'number', format: '###,###,###', columnCssClass: 'alignR', headerCssClass: 'xSmallFont' },//
{ headerText: 'SQL-SF IDs Updated Dt', key: 'sql_ids_updated_dt', dataType: 'string', width: "10%", headerCssClass: 'xSmallFont' }
