Good day!
We recently encountered a problem in igGrid. The problem occurs in selecting rows using Shift + ↓ (down key).
Kindly see below on how to replicate the problem. Take note that we are using Ignite UI 2021.
1. Select the first row
2. Press Shift + ↓ (down key) to select rows below
At first, all the rows that you selected will be selected properly.
But it you perform the same steps again, you will notice that the second row is unselected.
Please let me know if there is a workaround for this problem.
Looking forward to your support!
Thanks and regards!
Thank you so much @Arkan Ahmedov it's very helpfull.
tubidy tubidy
312
I noticed that the same question is asked in this forum thread where I have already provided an answer.
Please keep in mind that according to our support policy we handle single support case/forum thread per query. This helps us ensure that all your issues are addressed correctly.
I will continue assisting you via the forum thread so that other members of our community may benefit if they encounter the same situation.
Regards, Arkan Ahmedov, Infragistics
