15
Advanced Filter button not showing in complex objects columns
I am trying to remote filter and sort columns of a complex object, the problem is the button that show the advanced filter dialog is not showing. The column  is clickable for sorting but the arrows of the direction doesn't show either. The config of the columns are the same regarding the filtering and sorting.
Here is a fiddle with a small example, the example is with local data and filtering because the problem is just the ui not showing.
Thanks.
