I have a grid with row selectors and I'm using the gridRowSelectorsRowSelectorClicked event for when the user clicks on the column and not the checkbox of the row selector. Is there a way in this event to see if the row is being selected or unselected?
Ideally i'd like the information below that we can get in the gridRowSelectorsCheckBoxStateChanging event.
checkBoxState = ui.newState; isHeader = ui.isHeader;
Hello Tammy,
I am glad my suggestion helped you achieve your requirement.
Additionally, since the row state is not passed in the event arguments of rowSelectorClicked event, a check has to be performed in order to determine it.
Regards, Monika Kirkova, Infragistics
Thanks that will work. I was hoping for a more direct approach to avoid the looping.
After investigating this further, I determined that the state of the clicked row could be checked in a method bound to the rowSelectorClicked event. In this method it could be determined whether a row is selected by looping through all selected rows in the grid:
rowSelectorClicked: function(evt, ui){
var rowIsSelected = false;
$("#gridRowSelectors").igGridSelection("selectedRows").forEach(element => {
if(ui.rowIndex == element.index){
rowIsSelected = true;
console.log(rowIsSelected);
Below I am attaching a sample, demonstrating the described behavior. Please test it on your side and let me know if you need any further information regarding this matter.
igGridRowSelectors.zip
