Is there a way to always show checkboxes in igCombo dropdown list, even when multiselection is false?
Hello Ray,
I am glad that you find my suggestion helpful and were able to solve your issue.
Monika Kirkova,
I was able to use your suggestions to accomplish what I needed. Thank you.
After investigating this further, I determined that your requirement could be achieved by enabling the multiSelection. However,a constraint should be created to only choose one item, in a method, bound to onSelectionChanged. If the oldItems array length is equal to 1, the previous element gets deselected.
selectionChanged: function (evt, ui) {
if (ui.oldItems != null) {
if (ui.oldItems.length == 1) {
$("#combo").igCombo("deselectByValue", ui.items[0].data.Name);
$("#combo").igCombo("closeDropDown");
I have also changed the itemsSeparator in order to hide the comma after the items in the input.
Below I am attaching a sample illustrating my suggestion for your reference.
Please let me know if you need additional information regarding this matter.
5140.igCombo.zip
